mirra32 »
https://forums.nicoclub.com/mirra32-u19533.html
Tue Feb 20, 2007 12:38 pm
thats what i wanted to here....so direct bolt on as long as they are high impedance because the ka24de is high as well
EDIT
DAMN IT....i'm confused...i found this on a rx7 forum
quote"Now, having read that... I just checked a red-topped 195500-1350 I had here and it is NOT Peak and Hold (low impedance) DOH!!!
So the colors are NOT always correct! Stupid Denso. It would appear that they ran out of Purple and switched to Red resin 1/2 way thru making the 195500-1350's!!! When I called and asked them about it, they said, "Why are you trying to put RX-7 injectors in an MX-6? " ( I hung up while mouthing "mutherf**kers").
So I called witchhunter.com. They do nothing but rebuild injectors. He said "Denso is stupud. Forget the color, go by the notch."
On the square connectors, if the notch/indentation on the OUTSIDE of the connector is offset, it is HIGH impedance. Mine was offset to the right. If the notch is in the center (not the notch inside the connector), then it is the low impedance connector. The BOTTOM line was, if it plugs into your stock harness, then it is correct for your car's ECU"
so then my in injectors are high impendence
Modified by mirra32 at 6:43 PM 2/20/2007
