Got Resonator?????
max240se
Car: 95 240sx
hi all, simple question here, does our car (s14) comes with resonator?
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
Yep. I know because I ended up removing mine when it rusted all the way through and replaced it with a 2 1/2" aluminum pipe! Going to get the exhaust back to stock ASAP!!
ILikeMy240sx
Car: SR Power
yup yup... you can see it if you look under your car. It looks like a smaller muffler in the middle of the exhaust system.
max240se
Car: 95 240sx
thank you for all the reply....i guess my next question is, is it legal not to have it?
Axel Grungy
Car: 2001 G20 5spd
its just for sound deadening purposes, not emissions. so its just going to be louder.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Wow your question brings back memories. Anyhow I have a hotshot header which eliminates the downpipe and a 3" Apexi N1 exhaust. I left the CAT looking thingy on mine which was hollow but it made a droning sound at like 3000rpms so I replaced it with a straight test pipe and now it sounds so much better! The noise level went up a few decibels but it was worth it!
max240se
Car: 95 240sx
what high flow resonator would you recommend? i want to go the 'stock' route.
i guess i'll go with a bigger pipe from the cat, a high flow resonator then a not so loud muffler.
GhostDriver
Car: 1991 Nissan 240SX RMS13
Sounds like you need yourself a good ol' BRM.
OneBitchin240
Car: 1997 Nissan 240sx
yuh, i am about to get my exhaust completely redone with a hotshot header and new muffler and i was thinking it would be way too loud to not add a high flow resonator to the mix so i would also like suggestions on what kind to get
ILikeMy240sx: what will removing timing chain guides do?
Modified by OneBitchin240 at 4:51 PM 9/8/2005
ILikeMy240sx
Car: SR Power
you can click on my sig for more info...
If not now, it will soon start making noises and as time goes it will start to break into pieces and what not.
