datsunboy wrote:How do you figure that ( not saying your wrong ), but I have pulled apart a few JDM CA18DET's, ( in BOTH S13's and U12 bluebirds ) and that solenoid is used for the intake butterfly valves, and is not hooked up to anything to do with boost control.
also, check out the CA pinout diagram.....and follow the wire back from that solenoid, and you'll find it goes to ( forget pin number ) the Variable intake valve control on the ECU
S13 specific, there are up to 3 solenoids which are used. The solenoid located on the ignitor bracket is used as above, while the solenoid used to electronically control the butterflies is affixed to the vacuum tank bracket which includes the tank and 2 one way check valves. On Auto models there is also a separate solenoid which adjusts fuel pressure. This is also located on the vacuum tank unit.
As for the pic above, the ignitor and bits seem to be located on the wrong side on the engine bay, probably due to a conversion. Another give away as to the job af that solenoid is the different sizes of the vacuum lines. The large one 'T's into the turbo to actuator feed and the smaller one also runs to a 'T' which ultimately feeds back into the intake piping after the AFM and prior to turbo.
The english version of the FSM is actually only for the EURO version, not the JDM version.
