Got Q45 calipers
thekawaii
Car: box with 4 wheels
I bought it for unbelievable price. LOLI think I'm going to rebuild and paint it myself. Now I'm researching for Brake rebuilding and painting. Do you guys know any good sites for brake rebuilding and painting?
Camel
Car: That would be obvious....
How about a q45 fsm and a can of vht caliper paint. As well as the rubber kit and the clip kit. be sure to get 2 clip kits as it only comes with enough to do one caliper on the clips. the rubber kit comes with enough to do 2 calipers.
hannibal
Car: Red Line to Glenmont
PICS!!
thekawaii
price was right
thekawaii
second
Fat Felix
What is required to fit those onto a s13??
Tsukai240
Fat Felix wrote:What is required to fit those onto a s13??
dang beat me to it. it wiuld be cool if they were a direct bolt on without weird clearance problems.
slow s13
Car: cars, photo, music
They are a bolt on and since there sliding calipers they are much thiner on the wheel side of the caliper, I also got me a set for crazy cheap 30 some bucks, I gota get some rotors, redrill them. The rotors are 28mm wide. Oh yeah you can use your stock brake lines also because q45 uses banjo fittings.
Modified by slow s13 at 1:11 AM 3/28/2005
Tsukai240
wow cool just wish they were aluminium. still hot. even hotter with some sloted rotors. if i endup keeping my s13, i'm definately going to do this conversion!!!!(can't do z32 because of my funky arse wheels)
Neejay
Nice. I always said if I did a brake conversion, I'd go this route.
thekawaii
my plan was 300zx calipers but after days and days of research, found Q45 is good enough (and cheaper too)
Camel
Yeah, mine work great. I have had them on there for 4K miles now. Be careful about the bolts that mount the caliper bracket to the spindle, the stock 240 bolts must be cut down 1/4 inch to keep it from hitting the rotor. SS brake lines are a good bet as well, they help offset the squishy feeling you get from the bigger calipers. Although it isn't as bad as the Z brake swap squishiness (hehe). VHT caliper paint worked good for me as well. Bright Silver matches the stock SE 5 spoke wheels. Be sure to wire brush all the crap off before you paint them. 40% more pad area is alot of stopping force. They are easier to lock up, but if you know how to brake properly, they will stand the car up on it's nose. My calipers cost me 60 bucks used, but well worth it.
Fat Felix
What year q45's have the calipers that I need for my s13?
How about the rear??
edit: wait.... does this mean I'd need to be a 5 lugger?
Modified by Fat Felix at 9:57 PM 3/23/2005
thekawaii
any 1990 to 1996 Q45 modelthey all use same size rotor 90 to 96 rear... i don't know. i haven't try i don't think it'll fit.
cheez80
Car: percussion =D
unlike z32, the q45 brake conversion doesn't really have a front/rear bias problem.
therefore, stock mc, and no need for rear q brakes.
when you get brakes like these, and need to run 4 lug, you can always redrill the rotors to 4 lug. same with z32. it's not absolutely necessary to run 5 lug.
the q45 calipers will fit even stock s13 steelies, i think. or was it alloys?
Fat Felix
so no one really makes 4 lug rotors that'd work for q45 calipers?
cheez80
Car: percussion =D
buy 5 lug rotors, and have them drilled for 4 lug. any competent machine shop can do it, or if you've steady hands, you can do it yourself.
slow s13
I test fitted with the steelies..they fit!
slow s13
front side
slow s13
Another front side pic with the STOCK rotors. I dont have the pads and rotors yet I was just test fitting for the steelies only.
Chingon
Car: 1991 and 1992 hatchbacks
that's badass that the steelie clears...
BTW: q45 will increase your brake bias from 70% to 78%... http://forums.freshalloy.com/u...art=1
deezlins
Car: 95 240SX SE
in that link it says the 300zx front brakes bring it to 75% front bias, that doesnt seem like a problem to me?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Actually the 97-01 use the same ones.....
S13 owners generally dont use the rear brakes because the parkingbrake is different... The Q has a drum parking brake...
Im going to have a sweet set of drilled rotors and Q45 calipers for sale shortly!
