got problems... please help
drft@110
Car: 92 240sx
ok heres the problem. ive got an sr20 redtop, that dont wanna run right. the problem is that two injectors are not running. ive pulled the injector clips and the car still runs like crap. dose anyone know what the problem might be. it has a new harness in. im stumped :confused:
drft@110
Car: 92 240sx
:mike :poke: :slap: :wavey: :sad: :gotme :confused:
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Have you checked to see if you are getting power to the injectors?
drft@110
Car: 92 240sx
its getting 12v through the harness, but it is not getting signal from the ecu. ive checked the continuity in the harness, and its good on wires. ive tried using another ecu thinking that was the problem. but still the same thing.
sx moneypit
1986 Toyota MR2
Did you check it with a noid light or what?
drft@110
Car: 92 240sx
yeah i checked it with a test light on the ecu signal wire and used a meter to check the power wire.
sx moneypit
1986 Toyota MR2
I am thinking crank angle sensor but i don't see it affecting just two cylinders.
drft@110
Car: 92 240sx
its wierd. ive tried using a different c.a.s. im still lost on what the problem is
drft@110
Car: 92 240sx
would there be any difference in the redtops if it was pulled from an s13 or a s14
sldewyz
Car: 97' Danger Ranger
id say cas but since u tried that already...if your getting signal at teh injectors then id say that possibly 2 injectors are dead. pull the plugs out and the cas and then spin the cas (counter clockwise) and look down into the cylinders and see if its sprayin fuel.
sx moneypit
1986 Toyota MR2
drft@110 wrote:would there be any difference in the redtops if it was pulled from an s13 or a s14
I am not an SR expert but i think all the Redtops came out of the S13.Are you sure the ECU you tried is good? You might also want to pull the cover off the ECU and inspect it.
drft@110
Car: 92 240sx
the ecu is good. it came off a running car, and also double checked the ecu. also sldeways the number 1 and 2 injectors arent getting a pulse signal from the ecu.
drft@110
Car: 92 240sx
YO!!! any one else wanna try and help.
moch99
Car: 240sx s13 ka24e
im not sure but on some ka24e they have 2 injecter types 1 and 4 have 1 type and 2 and 3 have a diff 1
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
I'd probably guess your injectors are dead. They seem to have a ton of problems with em in these cars...
drft@110
Car: 92 240sx
would dead injectors not send a pulse from the ecu though. im gettin alittle frustrated with the problem. i know somebody has to know what kinda problem this is. im thankful for the help im getting.
Klits562
Car: white s13 coupe
Well considering you were able to get a working ecu from a running car why not try putting the two injectors from the running car to your car and see if that works if so then your injectors are dead, that simple seeing as you seemed to have trying everything other than replacing the injectors, process of elimination.
sx moneypit
1986 Toyota MR2
Since you say you are not getting the signal to fire the injectors and you have tried a known good ECU i would go back over your wiring very carefully and be sure and check your grounds.
drft@110
Car: 92 240sx
sounds good. ill grab the injectors off my buddys sr. and ill also check the wires. ill kepp you guys posted
drft@110
Car: 92 240sx
its been 2 months still nothing. the wires have been checked and the grounds have been checked. im grabbin some injectors later today. if anyone has some other info i would appreciate it alot.
drft@110
Car: 92 240sx
got the injectors from a buddy. and to no avail. the car still wont run right. i cant figure this out. any suggestions. please help. thanks
drft@110
Car: 92 240sx
dose anybody know what the problem could be? somebody anybody, please help.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Use a good meter with a min max capture, really check for voltage to the injector.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
it has been known for ecu's to burn out injector blocks on the boad with no sighn's of damage to the board its self...ive had 2 ka24de ecu's do that..both with cyl#3..you may have something grounding to frame or choking signal...but id do a few test's to be certain...ohm test the injectors just to make shure..then swapp ecu's& injectors...if none of those work..check timing.. ...it might be the maf,cas,or that pesky coolant temp sensor (possibly)...could even be a O2 sensor or a plugged cat...so many possibilitys you should really rule out the basics and then get back to us with what ya find..good luck
drft@110
Car: 92 240sx
its been awhile. since the last time. i have tried another ecu, injectors, maf sensor, it is still not getting a signal pulse from the ecu.
drft@110
Car: 92 240sx
anyone around new mexico or arizona area? i really wanna get this car running. please!
drft@110
Car: 92 240sx
anybody?
zachattack_5491
Car: Pignose S13 Redtop SR
I'm in New Mexico. Where are you located? I'm sure I can get it to work. I've even got extra injectors. Send me an email and I'll get you my number.
rioredstang
Car: 1993 240sx SCCA ITS
Have you pulled the plugs on the cylinders that are dead? Are they gas fouled, are they dry-snow white? You have determined which cylinders are dead, now what is compression? Did you put a noid light on the injector harness to see if it has pulse. I don't like to use a test light for injectors. I am not sure if its a injector problem. Which (2) are dead?
drft@110
Car: 92 240sx
the plugs are gas fouled. the no. 3 and 4 injectors are the ones that dont get an ecu signal. got tested with a noid light. im gonna run a compression test in the morning. i've checked the harness from the ecu plug to the injector plugs and there is no resistance in the wires.
