jamesmost wrote:My pinging was not in stop and go and thermostat was reading low.
Where is the fan relay, and which tab is ground ??
The temp gauge in the cluster is not linear. When it is in the middle you can have a wide range of temps.
I have a Techtom MDM-100 that shows me the temps from the coolant sensor. When the gauge gets to the middle, I have seen temps from 160 deg. to 220 degrees. The gauge never moved that much at all.
It was designed this way so as not freak out the drivers with too much information. But once you start modding a car, you can never have too much information.
I would get that Consult interface that was discussed on this board a few weeks ago. It seems to be a very good deal for the amount of info that it provides.
I paid over $450 just for my Techtom (this was over 5 years ago) and all it does is show me some of the info that the ECU is seeing. You can get the same features, plus more, in a Consult type interface for around $120 plus the cost of a cheap laptop.
As far as the location of the A/C Fan relay, it is in the fuse/relay box located behind the battery. When you remove the cover, you will see a location chart on it. Locate and remove the A/C relay.
Now you can figure out which socket is ground by using a multi-meter. The matching terminal on the relay is the one that you hook up your switch and wire to ground.
It is easy to do but just make sure you understand the concept before you start messing around with it.
