Grant@tirerack »
https://forums.nicoclub.com/grant-tirerack-u8792.html
Sat Oct 02, 2004 4:24 am
There are a couple of types of front camber kits we sell. The Eibach kit uses two upper strut spindle bolts. There are also two Ingals kits, one also replaces the upper spindle bolts and the other kit replaces both the upper and lower bolts. If you ordered either two bolt kit, it should be used on the upper strut mounting hole, not the bottom. The aligment shop will use those to adjust the camber.
