shadedoc »
https://forums.nicoclub.com/shadedoc-u11108.html
Sat Apr 03, 2004 6:04 pm
Q45Tech is right on the money(as usual). I'll try not to get too technical here, but if I digress, just ignore. If the vibration is between 12-17Hz (12-17 shakes per second) at a speed of 50~60mph, it is not caused by your drive shaft. The drive shaft turns at a much higer rate, hence the vibration will be at a higher frequency. Long story short, try swapping wheel/tire assemblies front to rear first. If it doen't improve, find a shop that will "finish balance" ("on the car balance") your front wheels. THIS WILL IMPROVE YOUR VIBRATION if it is a singular or combined weight induced vibration. Down side is that it will have to be performed each time you rotate your tires. Even if you don't rotate your tires, the force variation will change over time/driving and you will have to get it rebalanced.
The more detailed version:
If the shake in the steering wheel is oscillitory (rotational) rather than purley vertical or laterally, then this is usually caused by force imbalances at the wheel. The force excitation which causes the larger amplitude displacements which most customers complain about is a 1st order harmonic. This corresponds to once per revolution of the wheel. The force variations which cause the vibration can come from a varity of different sources. The tire, the wheel, the combination of tire and wheel, or any other rotating component at the wheel (hub, brake rotor, etc.) From a very refined perspective tires are never round, more egglike. This egglike shape can be the cause of your 1st harmonic. Tires are also considered springs, and just like the egg shape, their spring constant is not uniform all the way around, hence this can also be the source of the 1st harmonic. Wheel can have the same effect (egg shape) as the tire. Additionnaly, if the wheel does not attach exactly at the center of the wheel hub ( and it never is 100% true) this effectivly give youthe same excitation force as an egg shaped wheel. Usally peoplebalance wheel/tire assemblies on a traditional static/dynamicbalancer and then mount the wheel/tire assembly on the vehicle. But lets say the brake rotor also has an inbalance. If the wheel ismounted in such a way that the brake rotor imbalance adds to thewheel/tire assembly imbalance + wheel & tire R1H (spring etc.) you can have an ugly excitation force. Even a very good RFV wheel/tire assembly may not improve the vibration to a suitable level for you if you have other issues. Suspension geometry & bushings have a significant effect on this type of issue, but if you can remove the excitation force, vibration is gone. As far as temperature effects, tires will "flat spot" after sitting parked for as little as overnight. Usually the flat spots will disapear after driving about a few miles. However, if the weather is cold, flat spots may take longer to drive out. Different tires may have different construction that are more resistant to flat spotting. Worst tires for this are usually summer/performance oriented with Nylon cap construction (look at the type of belts in the tire, this is printed on the side along with tire size DOT code, etc.). I suggest increasing your tire pressure to the higherpressure specified on the vehicle tire placard to improveresistance to flat spotting.
