Yep, they had white walls, but he covered them up with a sharpie.R350Zz33 wrote:the 18's are back on and she is looking fresh i only paid $120 for 2 rears. they are slightly used but still have more tread then the stock ones had brand new.
I suppose its good you got new tires, but I'm curious...R350Zz33 wrote:the 18's are back on and she is looking fresh i only paid $120 for 2 rears. they are slightly used but still have more tread then the stock ones had brand new.
I asked the same thing and didn't get answer. Maybe I need to be blunt...marlin29311 wrote:Good to hear you finally have the correct tires again...what kind of tires are they?
FixedBusyBadger wrote: What BRAND and MODEL of tire did Mom get you?
I almost had some respect...and then you got two mismatching tires....its one thing to have different tires in the front and the back, but at least they match on the axel...R350Zz33 wrote:i got two different ones i know its not that good to be like that but she seems more agile now and very sharp steering response. both are run flats one is a Dunlop SP Sport 5000M DSST CTT(Ultra High Performance All-Season) and the other is a Michelin Pilot Sport A/S Plus(Ultra High Performance All-Season) both have lots of tread looks brand new.
I think it might be even worse than just unmatched tread. If the 2 tires he didn't replace were OE tires, then they're probably W rated I think the Michelin he bought might be Z rated, I'm not quite sure about the Dunlop. Not a bright idea to mix different compound tires eitherBlackSmoke wrote:Richie you mean you bought 2 different tires for the same axle. OMG You are to brilliant for this forum. Seriously save up and buy the match you dingleberry
Correction, unsafe temporary fix. Richie, that Z is clearly more car than you can afford to maintain properly, even with Mom buying it for you. You're digging yourself an ugly financial hole.R350Zz33 wrote:this is just another tempery fix to hold me off till work picks up and i get more hours
R350Zz33 wrote:i got two different ones new.
