got new shoes but...
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
logicmobile
Car: infiniti g35 sedan
ok have new shoes on my G, then took it to Xpr$$ tire for alignment later on after 3 days notice steering wheel vibration, took back to the shop to get re-balance , watch them closely if the wheel will turn Zero point, it did but still getting vibration, now the question is "can alignment could also cause vibration on steering wheel?? thank you
sexcpr69
Car: 2006 g35x
okay i know what you mean when i got my 20's on my g35x sedan i had the same problem and i had to go to different shops until i finally figured it out you need to make sure they balance the back tires because if u have no weights on the rim that could cause a shake and u might need the rim spacers im not sure if u have them last thing make sure they have a special wheel balance machine and its up to date alighnment shouldnt cause it to vibrate do u have a all wheel drive?
logicmobile
ok went back to the shop and re-balance again the wheels and still having same issue..steering vibration on 70+ mph what could it be? i only have 17 inch oem rims
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Had similiar problem with my 01 Pathy. Took it back to Tire Kingdom twice....still vibration over 60.Took it to where I should have taken it to, a family business tire shop and I believe they spun the heavy side of the wheel to the light spot on the tire??? Anyway, once they did this it was fine.
logicmobile
what do yo mean , and what did they do to your wheels to correct the problem? thank you
logicmobile
5 time coming back to the shop due steering vibration at highspeed turns out the tire itself is bad , we slap on new and different tire Nexen 5000 and runs great no vibration...the bad is the kumho LX platinum.. bad bad tire...never getting that again
logicmobile
i thought i fix the problem , i thought it was the tire, change the tire with another brand helps but now the vibration is come and go im in the frustration, it could be the anything around the suspension...
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
you might wanna go to a different tire shop. Sounds like the one you are working with can't balance tires.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
