Got new G35 lights! THEY DONT FIT !! any recomendation ?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Hookm36
Car: 2004 G35 coupe
I got some clear bumper lights, and the lights fit but they are loose. I realized the factory lights have a thin rubber like strip surrounding the light so that it makes a tight fit. What can I use to make the lights fit ? I dont want to glue the lights, i have tried adding a strip of doublesided tape but that doesnet work......anyone else have this problem ? or how did you correct it ?
Thanks
Hookm36
Car: 2004 G35 coupe
here is a picture
joe603
Car: 2014 Durango R/T
huh...weird. My clear corners came with the rubber strip. Where did you buy 'em?
Hookm36
Car: 2004 G35 coupe
got them off ebay........i prob should have spent more and got the "real"ones i guess
joe603
yup...they only cost $20?!
DragonG35
Car: 2007 G35 Coupe
Got mine off ebay as well and they worked just fine. I got the black ones instead of the clear. Try adjusting the clip on the back with a pair of pliers. With the side marker in position...just bend the clips back (inwards) to help hold it in place. It worked for me.
hydroeric2003
Car: 2003 6mt g35 coupe
try bending the clips or take the old clips off and use those thats what i did !!if all else fails use silicone !!
Hookm36
Car: 2004 G35 coupe
wasnt able to take off the factory clips, didnt want to break them, but i did modify the clips on the clear lenses, bent them outwards....it works !! at least for now
thanks for the advice!!
Hookm36
Car: 2004 G35 coupe
OK, got another question.....will the same light that fits in the side bumper lights also fit in the headlight housing for the light strip ? i think they are 194's i wanna make the dull yellow light, a bright white ! any help is greately appreciated !
Thanks
Return to “G35 and G37 Interior, Exterior and Audio”
