So then I guess you're saying those brake pads I have aren't the type with the shims pre-attatched?GnarKiller wrote:no need for shims.... unless your really specific about brake noise, but if you plan on running any knod of performance pads than the shims are just a waste of money spent elsewhere..
Zach
Thanks. I may just order brand new pads as well. If you look at the 2nd picture posted above, you can see on the clip on the pad to the left is bent on both sides. I was able to bend one side back to original form, but the other side is being a pain in the butt. I'm afraid to force it, because it may snap right off. What purpose do these clips mounted on the brake pads serve?AZhitman wrote:There's no shims on those....
May or may not need them. I'd recommend them though.
I was aware, but thanks for the tipGnarKiller wrote:true but if you are planning on runnign on performancepads like carbotech or axis prepare for brake noise because not because of shims or anything but because of the material they are made of.....
just so you know...
Zach
