Dat_82_720 »
https://forums.nicoclub.com/dat-82-720-u202232.html
Mon Apr 16, 2012 10:03 am
first off, the difference between the weber and the old hitatchi is night and day. It runs almost perfect. My question is that when you nail the gas, there is a slight hesitation before it will get up and go. Other then that there are no problems whatsoever. What would cause this and is there anything i can do to reduce or eliminate this? it is an 82 Z22 2wd. If it makes a difference, i removed all vac lines and the egr is sitting open right now, because i didnt have a hose to connect it to the new air cleaner yet
