jfanaselle »
https://forums.nicoclub.com/jfanaselle-u73887.html
Thu Jan 24, 2008 3:04 pm
Ok it's installed. Took me about 10 minutes total. The only complaint I have is this: It seems to be a somewhat universal bar with vehicle specific brackets. In order to fit, I had to remove the two nuts on the adjustable end pieces (the ones that look like a tie rod) so that it was narrow enough. These are the nuts that you would tighten agains the bar itself after adjusting the ends.
However, once I tightened everything down, it's very snug and works great! I took it for a spin and it's a very noticable difference. This is definately an upgrade that's worth the $40 and I would recommend it to anyone.
I plan on going to Lowes or Home Depot to pick up some thinner bolts that will fit on the adjustable end pieces so that I can snug it up a little tighter though.
Here are some pics:
