neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Mon Aug 13, 2007 11:38 am
IF anyone was going to its him, again IIRC 510 dyno a tad higher than a 240...
but that combo should make an easy 215, I HOPE.
hey yellowcar you ever drive a ka~t? If you have not maybe you should, not an uber t4 but a simple t25 7psi ish... its amazing trust me. I just went boost on a 400$ motor I didnt even comp test, spent 200 on boost parts(a thread in the 240section can be found with my name), and IF I wasnt a broke mofo right now I'd bet it makes 220wheels at 6psi with my non tuning ***. even with exhaust leaks it at full spool almost any time(its adjusted at the wastegate arm so the flapper is open all the time, a lil). But I have NEVER drove a 200whp na ka so what do I know lol. not trying to push boost on you man I'm just hook'd hard on the stuff. btw heat is a small issue, dual efans own though I think the car runs about the same heat, but underhood temps are up I'd say a min of 100*. good ole hood prop mod ftw
