got my sr20 on the road today
goixiz
Car: Cycling and cars
with a JB weld temp fix radiator
The problem now i face is that in 4th gear it pops out of gear into neutral
and during acceleration i hear this hissing sound ( I have HKS intake filter) - whats this sound ?
slw240sx
Car: 1990 Ca18det 240sx Hatch
ummm turbo spool, maybe , you ever driven a turbo car before?
goixiz
not the wind up or whinning noisemore like air out
what to do with clutch coming off
goldollar
Car: cars
more detail on the hissing noise, and did you replace the clutch, what kind of condition is your trany in is that the only problem
goldollar
Car: cars
your the guy that got his motor from jarco right, where in GA are you
BuudWeizErr
I know exactly what hissing sound you are talking about (i think). It's during low boost, like when it's spooling up. And you usually aren't flooring it, more like moderate acceleration, and it sounds like it's coming from the turbo. I have yet to identify the source, I've sprayed carb cleaner all over every one of my couplers and it never surged, I took all my piping off and reinstalled it, still the same thing. I have no idea what it is. Maybe someone else can help out here? It almost sounds like something metal on metal, but I know the turbo isn't blown because A) it was just off a couple months ago with 0 shaft play and B) stock boost.
:dunno:
slw240sx
ryan, check your BOV !!! it maybe "loose" and leaking air during spool up.. it will hold under boost. but not on spool up ! mine was doing this ! packed some quarters into it to tighten the spring up and it solved the problemn
goixiz
goldollar wrote:your the guy that got his motor from jarco right, where in GA are you
Yes i got mine from JArcoif you like email me offline
goixiz
goldollar wrote:more detail on the hissing noise, and did you replace the clutch, what kind of condition is your trany in is that the only problem
Did not replace clutchIt was still good and looks goodmetal surface looks good - must be recently finished
Hope its not the transmission internalsSyncros or shift forkIf it is how hard to repair it ???
what else to look for ????
goixiz
slw240sx wrote:ryan, check your BOV !!! it maybe "loose" and leaking air during spool up.. it will hold under boost. but not on spool up ! mine was doing this ! packed some quarters into it to tighten the spring up and it solved the problemn
YES sound just like thatTell me the spring size and ill replace it and ill send you one if i can get it
Need spring infoWire diameter Heightouter or inner overall diameterK - spring constant but i can figure that outif you know the number of coils
goldollar
Car: cars
it could be your clutch, or your pressure plate, had a freind who had a similar problem with his accord he got it replace and it was fine, i dont know if that will help you, but it a start. if its yur transmission good luck i havent personaly rebuilt a transmission but from what if heard its not easy and its expensive to have someon to do for you,
Cyberkreig
Car: 1993 Nissan 240SX SR
BuudWeizErr wrote:I know exactly what hissing sound you are talking about (i think). It's during low boost, like when it's spooling up. And you usually aren't flooring it, more like moderate acceleration, and it sounds like it's coming from the turbo. I have yet to identify the source, I've sprayed carb cleaner all over every one of my couplers and it never surged, I took all my piping off and reinstalled it, still the same thing. I have no idea what it is. Maybe someone else can help out here? It almost sounds like something metal on metal, but I know the turbo isn't blown because A) it was just off a couple months ago with 0 shaft play and B) stock boost.
:dunno:
I have a very similar air hissing sound. It is most prevalant at idle.. but it hisses until about 2800rpm.
BuudWeizErr
slw240sx, I have an SSQV, how do I put quarters in there? I'll tighten it up tomorrow when I get my new clutch master; see if that fixes anything.
T_love
My GT did that popping out of gear thing in fifth gear last year while i was driving to Indiana. Turns out 5th gear was destroyed and i had cracked the housing. I really hope it's something else in your case coz i had to shell out a crapload for a rebuld.
spyhunter
indeed on the rebuild, i had the dreded b12 5th gear pop up problem as well. oh well
goixiz
can it be fixed ?ANd how hard is it or do i have to get a new transmission
JARCO screwd me again
slw240sx
well im not sure how to Adjust the hks super squential BOVs but i know mine just comes apart and has a spring inside and inorder to put more pressure on it you add "pack" washers! we were out of washers so quarters worked ! you might just be able to screw the bov tighter? did you adjust it when you got it ? it may need to be adjusted
slw240sx
Quote »I have a very similar air hissing sound. It is most prevalant at idle.. but it hisses until about 2800rpm.[/quote]
for some reason thats when the BOV most liked to open on my car when it wasnt adjusted right! it caused some irratic idle and slugish response down low since it allows the car to run overly rich untill on boost when it stops leaking !
BuudWeizErr
Nah, I tightened it, it didn't really seem to make a difference, seems more like it just made my BOV vent shorter and higher pitched.
Cyberkreig
slw240sx wrote:for some reason thats when the BOV most liked to open on my car when it wasnt adjusted right! it caused some irratic idle and slugish response down low since it allows the car to run overly rich untill on boost when it stops leaking !
hmm.. unfortuantly i have the stock recirc valve.. so adjusting probably isnt possible.
slw240sx
it may very well be blown then !
cybin
This months Sport and Compact Car had an article all about BOVs. They menchened something about crushing down the cap to tighten up the spring rate. I think its only for mitsubishi BOVs but alot of car makers use there valves.
-Cybin
goixiz
goixiz wrote:can it be fixed ?ANd how hard is it or do i have to get a new transmission
Sometimes excitement and dissapointment over shadows what i say online here.
After a month or so im starting to loose hope when things dont go well together. So what i will do is it give the cluthch and shifter a few more adjustments and see where it goes. I sure hope the transmission is fine otherwise ill be sad.
But thanks for everyones help and recommendations
Ill try to engage brain and disengage feelings before posting(key word is try)
thanks all
turboex
Hey man for the 4th gear problem you have, mine did the same thing. Check the rubber boot that bolts to the botom of the floor of your car before you do anything else. If it is in any way but the right way it will pll hte shifter out of 4th gear and only 4th gear. This should fix your problem.
goixiz
turboex wrote:Hey man for the 4th gear problem you have, mine did the same thing. Check the rubber boot that bolts to the botom of the floor of your car before you do anything else. If it is in any way but the right way it will pll hte shifter out of 4th gear and only 4th gear. This should fix your problem.
Somehow i think you are right I will check it tonightand sure hope so
Thanks a lot
will let everyone know
goldollar
Car: cars
hey goixiz did you get my email
goixiz
goldollar wrote:hey goixiz did you get my email
Sorry no email recvd here nor my home
goixiz
NOPE took the shifter and boot of and have rubber boot loose and still popped out of gear only in 4th
and i Have new clutch slave cylinder (original from SR20)
I guess will have to let JArco know and see what they plan to do. Ill post this is something i will not let slide like the rest of the things that happen with this 1/2 cut
Drakon
Car: S13 hatch-SR+bpu's
Does is make that noise for a little bit when you turn the car off? just wondering if its the vacume lines...or your air filter could posibly cause that noise. i duno.
goldollar
Car: cars
hey you can always use the ka transmission if all else fails, but yeah stick it to jarco. Let em know whats on your mind
