xjon wrote:I had that same problem. For the brake light I just removed the bulb. I am not sure about the door light though. My low fuel light has never worked to begin with so no problems with that. Either way, I didn't think I needed those lights so I just unplugged them. I just made sure that my engine light is hooked up. Pretty much all I cared about.
I got power from those wires BTW for my AF meter and boost gauge so I thought I messed it up or something. I guess it is a common problem.
no no no, the light itself isnt the problem its the WIRING on the cluster. nissan used the low fuel light for a junction for a bunch of ****. if you remove that light all your other ones will go off when you remove the key
just try it and trust me.
