Got my parts from Joe.
FarFetched
Car: Suzuki SV1000S.
Finally, I got KS, spark plugs and turbine sensor. I will digg in sometime this week.I don't want to remove transmission . That turbine sensor doesn't look that scarry (long) and I should be able to squeeze it in .I hope after all that done my Old Lady will become "like a virgin" once again. Cheers!
Q451990
Never heard of replacing the sensor without at least dropping the front engine brace and mounts... except for someone who cut a hole in the floorboard.
Heath
FarFetched
I am going to lower engine/susp cradle to gain more access!
5zigen
Where on the website were you able to find the sparkplugs? I could not find them anywhere.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
5zigen wrote:Where on the website were you able to find the sparkplugs? I could not find them anywhere.
Always call to confirm availability and correct part number. Not everything is on the web.
FarFetched
Go to "SEARCH BY PART NUMBER"http://www.trademotion.com/par...id=55 and type in 22401-1p115Cheers!
FarFetched
I still can't believe that those little devils "KS" are so expensive!
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
FarFetched wrote:I still can't believe that those little devils "KS" are so expensive!
If you find 'em for a '90 after market they even more expensive than you you can find anywhere dealerwise !! (Thanx Joe !!)
YA '97 I know
"Someone" doesn't recommend cutting the floorboard just the trans tunnel, unless you want to piss away 2 extra days.
Q45tech
Where's the KS sensor harness in picture........the critical replacement item.
DrewQ45
Tech,
Can't you see he made a smiley face out of the items?
Including the KS would have ruined it!
..Drew....
FarFetched
Q45tech wrote:Where's the KS sensor harness in picture........the critical replacement item.
Please explain why is it so critical. I know connectors are prone to loosen over time, but if there in no voltage drop (resistanse) across connector, it should be OK!Just wanted to know!Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Why didnt you get your spark plugs and KS from me ????
Take lots of pics, we know you have a camera!!!
FarFetched
elwesso wrote:Why didnt you get your spark plugs and KS from me ????
I don't know! I will take as many as I can...
DAEDALUS
FarFetched wrote:Please explain why is it so critical. I know connectors are prone to loosen over time, but if there in no voltage drop (resistanse) across connector, it should be OK!
It's not the voltage but the signal/frequency that's critical. Connectors are known to be problematic on the injectors, CAS and MAF; no reason the KS would be an different. There is a difference in the labor though, and spending $35 now (or whatever it costs) makes a lot of sense to reduce the risk of having to redo this job in the near future, especially since you just spent over 10x that amount on the other stuff.
Q451990
I went down the road of replacing the sensors and not the harness... don't waste your time pulling the plenum twice!
Heath
Q451990
squeefoo wrote:"Someone" doesn't recommend cutting the floorboard just the trans tunnel, unless you want to piss away 2 extra days.
Sorry, I never can remember who came up with that idea! Did you happen to take pictures?
Heath
FarFetched
Heath
In case of Y33 you DO NOT have to remove plenum. Just take alternator out, upper t-stat housing(by-pass) and you are in! To R+R harness you don't even have to undo t-stat housing (by-pass housing). Cheers!
