Got my megan racing short shifter in!!!
asher4857
Car: '89 240SX Fastback
My short shifter finally came in!!! I got it off of undergroundmotorsports.com. Awesome for only $50. Cant wait to install it.. heres a pic of the kit
naed240sx
Car: .....
looks decent. Be sure to post up after installation, I would be interested in getting one myself. Does it come with that shift knob attached?
Fenvy
Car: 2005 350Z Base 6MT
sorry not to be mean but from personal exp it's probably crap
I thought shifter are all the same but I was wrong, I bought a similiar one at a similar price and I changed it back to stock within 12 hours
one issue that I can see is the pointy part on the bottom, the part that do the actual shifting, does not match with the internal shifter linkage very well (I don't know what else to call the thing) and the shifting, although shorter, will be rough
I ended up getting a C's short shifter
asher4857
hmmm.. im hoping that is just something that happened to you, ill see how mine works.. ive read a lot about it and people seem to like.
and yes, it comes with a metal shift nob attached to it but because it will heat up fast, im just gonna change it out for the stock one
Ill be sure to post pics when im done and tell you how i like it
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Great looking shifter! Just remember that you need to take the plastic cap off the end of your stock shifter (around the ball at the bottom) and put in on the short throw one. I got the OBX shifter myself and it didn't come with a new cap on the ball. When I installed it without one it was real mushy and loose while driving. If you don't you'll see what I am talking about! Be careful removing the cap though it's a B*#$&! Try not to break it either!
asher4857
does anyone know where i can get a write up for the install? i cant seem to find anything for the megan racing shifter..
naed240sx
Car: .....
Loveless wrote:sorry not to be mean but from personal exp it's probably crap
when you say rough, do you mean like a very non-positive engagement, grinding or what? Cause I already have a few grinding issues and probably wont get a ss if it will make matters worse
Fenvy
naed240sx wrote:when you say rough, do you mean like a very non-positive engagement, grinding or what? Cause I already have a few grinding issues and probably wont get a ss if it will make matters worse
it was som pathetic, some gears are tight and some gears are lose. Some gears I can move around while it's in gear, some gear felt longer while some felt shorter. The whole thing just felt loose and cheap.
Short shifting is not good for your transmission from what I read because you need to give time for the syncros to match. To combat this, I usually shift slow unless I am in a playful mood.
asher4857 wrote:does anyone know where i can get a write up for the install? i cant seem to find anything for the megan racing shifter..
search is your new best friend, I beliueve there are more than a few thread pertaining to SS install on 240sx and its counterpart motors. But here is a good write up on zilviahttp://www.zilvia.net/installs/obxss/doc.asp
ddgsxr504
I think he meant that the shifts aren't smooth. You know how when you shift it almost shifts itself, with a S/S you have to actually push it into gear. Getting one for my S14 was one of the best things I ever did. I love it over stock. The only thing I didn't like was that it was the same height as the stock one so I fixed that by cutting it and rewelding it together.
Twinchy
Car: Peg leggin 240sx
i agree with loveless.that short shifter sucked. i had it on for about a hour a took it off. it felt like sh*tso i just kept the stock shifter on.
PalmerWMD
Car: 2004 350Z
I have a B&M Short Shifter in my car and its the best, most positive and exact (yet smooth) engagement I have ever felt in a manual.
Too bad it rattles terribly..
Paid $175 (local pick-up).
Cant wait to hear how it works for you..
Fred..
Rosco
Car: 91' SR'ed Hatch
How does B&M compare to C's???
GrubyFngaz
Car: 2001 Infiniti QX4
I agree with Loveless to, it sucks, i tried this one and a B&M knock off from e-bay which doesn't rattle but it doesn't really feel much shorter than stock. From my experience B&M is the only way to go and that's if you can deal with the buzzing noise. Hope it works out for you though. Let me know if you find out a way to make it work better, I'll try putting it back on.Josh
lrb_2000
Car: '91 Nissan KA-T hatch
is the buzzing only on s14's? i've never heard my b&m make any noises... I love it, the throw is so short, and smooth.. When i first installed it, I was confused everytime I shifted thinking it wasn't in gear, especially reverse.
Fenvy
lrb_2000 wrote:is the buzzing only on s14's? i've never heard my b&m make any noises... I love it, the throw is so short, and smooth.. When i first installed it, I was confused everytime I shifted thinking it wasn't in gear, especially reverse.
it affects the ca, ka, sr, rb
only some of them rattles
b&m later came out with a v2 of the SS that supposedly doesn't rattle
tonynalli
i bought the exact same shifter from teh same person. it didnt come with any instructions and i didnt have any freinds that could help me, so i ghetto rigged it in with some jbweld and a few other things and it worked for about 1 week. but since i do a lot of drifting and since it rattles like a mother****er at about 5000 rpm i got rid of it. hell i couldnt even hold onto it while i was driving.it tore the plastic shifter cup to shreads about twice a week. they sell them at the dealership for about 1 buck a pop. if you do decide to use it buy yourself new ones.
i do rember seeing after about 2 weeks after i got mad and threw all the **** in the woods i found instrucions online somewhere on how to put that exact one that i had in, i was kinda pissed but...
asher4857
hmm.. im not liking how this sounds.. hopefully i mine works well.. and if not, underground can expect me calling them asking for a refund..
asher4857
i dont know what all you people are talkin about.. i dont know if you guys got the same kit i did because mine works wonderfully.. such an easy install.. pretty much self explanitory.. we had one question though and Chris from undergound answered it with just one phone call.. i highly recommend this shifter to anyone and especially from underground. The throw feels so smooth and so short.. 2nd to 3rd for the first time was incredible.. kit came with absolutely everything needed for the install..
overall an incredible deal.. product.. and improvement.. all for $50.. buy it...write-up and pics coming soon
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
I agree with asher, we did this install in about a half an hour. test drove it right after the install and it worked just fine. shifts were shorter and smooth as well. Went through all the gears and no problems.
ddgsxr504
Congrats on the install. I loved mine and I still do! Some people are just hard to please, you have to remember that you are driving a Nissan not a $100,000 Porshe so it's supposed to be fun not perfect!
fatboy
Car: s13
ive never been too big a fan of short shifter. i like my stock shifter
ddgsxr504
Maybe you just haven't found the right one yet. I tell you what though if I had a extra $11,000 lying around I would definitely pick up one of those HKS sequential transmissions! HOT!
paemt6220
Car: 1997 Maxima SE 5MT - MODDED
So no problems with the Megan racing shifter!? If thats the case, I'll buy one. I have delt with Chris before, great guy!!!
Chad
asher4857
yea dude deffinatley.. get it from undergroundmotorsports..
that was the easiest install ever.. well have a write up and pictures on the write up soon to come
ddgsxr504
Hey paemt6220, how are you liking those Megan Coilovers? I want to get some but I hear they are a little stiff but others like them alot?
GrubyFngaz
If anyone wants to buy mine, I'll sell it for $5 plus shipping. I have the exact same stuff pictured at the top of the post, used for maybe 2 days. So just let me know.Josh
tonynalli
GrubyFngaz wrote:If anyone wants to buy mine, I'll sell it for $5 plus shipping. I have the exact same stuff pictured at the top of the post, used for maybe 2 days. So just let me know.Josh
i guess ill take it from you. email me at tonynalli@yahoo and we'll discuss it later. i guess i sound like a hypocrit but if they say that it worked i would belive them i guess. and i really want a short shifter. but how does it sound when you going through the gears? does it rattle like a muthafuka?
Modified by tonynalli at 10:44 PM 8/25/2005
asher4857
no not really.. ive had it on since yesterday, and ive only heard it around 3.5 - 4K but its only for like.. a second.. if anything.
but since i shift around 3, and play music, i dont hear it at all..
if you need any help installing it just let me know.
ddgsxr504
Did you take that plastic cap off the stocker and put in on your short throw like I mentioned, or did yours actually come with one? Mine didn't!
asher4857
im assuming you are talking about the small little cap thing that goes on the smalll ball.. yes, mine was in the box. Brand new. as well as the larger plastic ring that goes inbetween the big ball and the big cyclinder. We had to cut through part of it in order to open it a little and put it on the shifter
