DRIFTEADOR »
https://forums.nicoclub.com/drifteador-u23379.html
Tue Mar 22, 2005 7:59 am
you should know, in-tank fuel pumps, even the "hp" model, can't deliever necessary flow at high pressures like youre asking it to. look at their own flow vs. pressure chart for proof. if you're running a fmu, which btw, is the worst type of fuel managment (if you dont believe me go dyno with afr and watch your motor lean out anywhere close to peak tq, and go pig rich there after until redline), at least have an inline to go with it. imo, no fuel system should see more than 60psi. youre running it at 120psi @ full boost. something will fail
Modified by DRIFTEADOR at 10:12 AM 3/22/2005
