Got my engines!
boost_boy
Quote »Damn the bad rings....[/quote] They are naughty, arent they:D .
Dee
biosehnsucht
Thats what boring the block to 84mm and putting in nice shiny new CP pistons are for !
float_6969
$, dinero, moola, cash, dough. Yes, I'm lacking in all of these...
PalmerWMD
Car: 2004 350Z
What a cool project.
Also rememebr guys a self addressed (legibly) stamped envelope sent to me gtes you NICO stickers.
Fred...:)
biosehnsucht
Heh, I'm trying not to sticker up my car.. otherwise I'd have a ton..K&N, AGX, Eibach, a few from places I bought stuff at, ...
It's like I'd like to give credit to what I've got, but at the same time stickers often look tacky.. esp if you have a bunch, unless its like a race car painted and stickered accordingly, but my car's paint is all fubar anyways.. I think someone before I owned it said "gotta get Maaco"..
biosehnsucht
Made tons of progress on L motor
Well, I forgot to get pictures of removing the pully, I was too tired.. in order to get the huge 5 ton puller on we had to dremel-sand down the edges of the pully between the innermost and center belt sections so that it could get through at an angle...
also at that time got a bunch of the oil/water fittings for the turbo etc off, and the pistons out
that was ... wednesday night?
then that night while taking friend home smelled fuel.. uh ohpopped hood at his place, the fuel line hose I had bought at the auto parts place (forget which) apparently isn't spec'd for high pressure EFI duty.. and was bursting and the clamps I had were not proper..
luckilly he had some spare high pressure hose and proper clamps, we fixed that up, but it was like 4am in the rain.. ugh
tonight we got alot done, got the main bearing caps and the girdle off, and a few other things..
..and got the god damned timing belt pully/gear off!!!had to cut it up w/ dremel from two sides and then beat the @#! out of it with a screwdriver and hammer (actually, started on one side, then my friend Josh (helping friend #2) said "Hey, why don't we cut it where the key is, so we don't have to cut as far?" and we more or less said 'DOH!', spun it around and attacked that side.. the key helped protect the crank while we went at it with the dremel and were able to get far enough in that some proper beating with the hammer and screwdriver popped the sucker..
at that point pulling the oil pump off, the crank out, and the bearings out was easy.
about this time we went hey, why do we still have the water pump here? and took it off.
haven't figured out yet how to get the oil filter mount off yet..
anyhow..
my first timing belt gear cherry:
near-empty bottom end:
about all thats left now is the oil piston squirters, the oil filter mount, possibly that one big stud on the front (forget what goes on there, its that 4" or so sticking out one), the water inlet...
then its ready to go off and be tanked and bored out, etc !
Modified by biosehnsucht at 5:09 AM 1/15/2007
slw240sx
Car: 1990 Ca18det 240sx Hatch
doh i knew i forgot to order somthing! new timing gear.
biosehnsucht
Yeah I'm thinking the timing gears are like oil filters..
boost_boy
Now that was about the nastiest CA bottom end I've ever seen.
Dee
float_6969
Yea, i don't think I've ever seen one black. I was complaining cuz mine was brown. I'll shut up about it now!
biosehnsucht
the oil was horrible death evil incarnate black, the sort that would make blackholes stand out O.o but in some ways the pics make it look worse and in others better, mediocre camera and absolutely horrible lighting.
NeedCAforS13
Car: CA swapped S13 coupe
the oil filter mount has 4 bolts and then should just pull off... it has a paper gasket that hardens so that might be holding it on, but just whack at it with something and it pops off:)
Sean
biosehnsucht
thanks.. should I remove the water inlet to get it tanked? can't tell if its something meltable or not..
and any suggestions off-hand for the oil squiters? I noticed they're 12 point
float_6969
Umm get a 12pt socket?
biosehnsucht
I mean, no fancy tricks just unbolt them?
a friend of mine mentioned on some engines he'd think (I think mazdas?) you had to drill them out and replace them or something destructive like that..
NeedCAforS13
no they just come out with a 12 pt socket... just watch your knuckes, I banged mine up REALLY well on the engine stand when I took mine out!
Sean
~*IdIoT bOx*~
Car: cars
wow, its coming along well.
Keep the pictures coming :)
Andrew.
biosehnsucht
Joe's old HT SS showed up back on monday, due to various reasons (power outage, hanging out w/ friends, etc) haven't actually gotten around to taking pics till earlier today.
I should have another update I hope later since getting the oil filter mount and oil squirters off shouldn't be too much of an ordeal..
for now, the HT SS downpipe I got from Joe, with the usual bad lighting:
biosehnsucht
ALRIGHT!!!
Got L motor block completely stripped and boxed so its easily storable/transportable, R motor almost but ran outta boxes (need one for crank and one for block)...
my (plastic) 'crate' engine, L:
R (look closely and you'll see I got the damn belt gear **** off):
side by side (L is in the bottom right plastic box):
....Now, wondering still if I should be taking the water inlets off?
Also, do I have to worry about this little ball gizmo under the oil mount when I have the motors tanked?:
Modified by biosehnsucht at 5:10 AM 1/15/2007
boost_boy
It's the oil pump prssure relief! just make sure it's functioning when it returns.
Dee
slw240sx
man i feel bad now, and kinda worried i didnt completely disasemble my motor at all, i left the oil squiters in the oil filter block on, the crank and mains on. everything least the motor builder is good at not breaking or loosing parts
biosehnsucht
I made sure to get the squiters cause someone in the past few months had their shop lose them (luckilly they found them again)..
so what about the water inlet pipe? somehow break off, or not worry about it?
nab911
Car: 93 Nissan 240SX SE
that was ca18detsilvia... i remember his ordeal
pulsar gtr
Car: NISSAN VEHICLES
I have taken the water inlet before, it is glued in , you need to get a hammer and gently hammer it out side to side at the same time try to pull it out, it will come out, it isn't that bad.
PULSAR GTR
biosehnsucht
Do you mean hammer one side straight on, then the other, repeat, or at an angle, such that the force of the blow would try to pull it away from the block as well as knock it loose?
pulsar gtr
yes sir, you got it,
PULSAR GTR
biosehnsucht
yes, but which way? :P
biosehnsucht
WOO WOO!!!!!
I'll let the pictures speak for themselves!edit: None of the rings, didn't want to take them out of their wrapping..
now I just gotta knock that water inlet off and cart if off to get cleaned up, bored out, etc!
biosehnsucht
Got them through Race Engineering..
here's the Specification Sheet (left out blank stuffs and the order# stuff at the top)Dimensions are obviously in inches, not mm.Not sure what meaning cam profile has, unless thats what they use to determine how much dish they need ?
Forging: 82-2Bore Diameter: 3.307Clearance: 0.0035Compression Height: 1.181Piston Size at Gauge Point 0.5" up from Bottom of Skirt: 3.3035
Top Groove Width: 0.042nd Groove Width: 0.0483rd Groove Width: 0.111Top Groove Diameter: 3.0082nd Groove Diameter: 2.9843rd Groove Diameter: 2.992
Intake Valve Relief: -0.1Exhaust Valve Relief: -0.100
Dome Height: 0Pin Diameter: 0.787Pin Length: 2.25Lock Type: .050 Wire
Gram Weight: 303Cam Profile: CP832XSS
pulsar gtr
WOW, sweeeeeeeeeeet.I like, I like alot.
PULSAR GTR
