(This is a question) but sounds like them screwing with your camber angle would kill the life spanned of your tires right or wrong? If correct, I would not want them adjusting that to my car if it's a daily driven car. I think I'm about to get it with this question, but I thought it's a good question.Kango wrote:Your camber angle is negative. Lets say you look at your wheels from the back of your car... the bottom part of the wheels are gonna be further away than top. Caster i believe is for your front wheel... how it pivots when you turn those wheels maximize the tire contact to ground when youre turning.. Toe is another angle for your front wheels. Lets say you're looking at your front wheels from above the hood(Somehow through the car hehe =)... you have positive toe... or your front wheels are not parelle... but pointed slights towards the middle.Hope this helps. Modified by Kango at 10:17 PM 1/9/2009
This is confusing to me.Beak wrote:let the spings settle for a week or so.. then get an alighnment. when you drop it the alighnment so all out wack.
