Well, the fronts at least. I ran into some issues with the rear, both lower shock bolts are seized in the bushings, so I'm not looking forward to having to cut the bolts out and press new bushings out and in. I guess that's to be expected with 10 years and 206,000mi, especially with salted roads. I ended up originally lowering the front 1.5 inches but it had too much rake without having the rear done, so I brought it back up another half inch. The rear sits at 28.5 from ground to fender lip, front now sits at 27.5. Even with the front done, it's AMAZINGLY better, the factory struts were terribly worn. I have them set 13 clicks from full soft, and want to play with that a bit more.
