No, the maps are completely custom, the tech recommend some map options but its completely up to you. Just tell them what you want and order you want the maps in.WirelessAndy wrote:Out here in CA, we don't have readily accessible (that I know of) 93 octane. Is it mandatory you get the 93 octane map? Or can you specify which map(s) you get, and in what order?
How long did the entire process take?
I'm still very, very curious: If you bring this into the dealer in "stock" mode, do they check the ECU for any reason and would the presence of the other maps be an issue?
No TCU control from uprev or any other tuners for that matter - you only get that on domestics since they actually like the aftermarket where as japanese auto manf try and make their ecu's un-hackable due to their strict vehicle, traffic, and emmision laws.tytamto wrote:Are UpRev tuners able to mess with TCM programming as well? Or is it all ECU?
Gotta love the cool weather and good gas! Those are great numbers for a stock car.hugedude33 wrote:
RunFile_001.drf Max Power = 271.29 Max Torque = 289.12
RunFile_005.drf MAx Power = 281.18 Max Torque = 300.40
Gains: 10rwhp & 11rwtq
Fuel: 93 OctaneRun Conditions: 51.53 F, Humidity: 21%
Wow. I JUST got this email from EIP Racing in Milpitas, CA (copy and pasted):hugedude33 wrote:The UpRev Osiris Reflash Stg1 $300Dyno Tuning $175
Total cost with tax was $503
What kind of dyno did they use to tune? was it on rollers or did they take the wheels off and bolt it to the hubs?
Actually, thats about right. the place I went to charge $175hr. most of the time it take 2hr to really tune it good. they tuned my car for 1hr cause im going back in about a month to have an exhaust put on. at that time they will tune it again for another hour to get it just right. So when it all said and done it gonna be $350 for tunig. With the exhaust added, I should see another 10hp and 10tq. bringing my total gains to 20rwhp and 21rwtq, HOPFULLY!!!!!!WirelessAndy wrote:
"is gona be $300.00 for uprev software and $300.00 for dyno tuning"
I pray they were typing that on an iPhone or something. Will take about 3 hours.
According to their marginal webpage, they use something called a Mustang Dynamometer MD-AWD-500.
they did a total of 5 runs on the dyno.WirelessAndy wrote:So lemme see if I understand this.
They upload some maps of your choosing (91 octane, Stock, valet, etc) and hop your car on a dyno.
They watch the plot. Hm, let's tweak this parameter.
Dyno run again. Repeat as necessary.
Sound about right?
Nope - they load in the ROM file which turns the stock ECU into a fully customizeble ECU with storage capacity for 5 separate maps that can be tuned individually. Then they strap it onto the dyno and custom tune it to maximum depending on your setup.WirelessAndy wrote:So lemme see if I understand this.
Sound about right?
Yeah - at 5000rpm the power valve in the intake manifold opens effectively reducing the runner length in the intake manifold which is better for high rpm horsepower. The dip is because the split second it opens it causes hella turbulence reducing airflow for 100-200rpms and it takes a little time for the valve timing to catch up to take advantage of the lower restriction airflow after the valve fully opens.hugedude33 wrote:Ken, I was looking at the chart and I notice a dip in hp and tq around 5200rpms. The tech said its what you call a butterfly valve and its not much you can do about it. Do you know anything about this.
You normally keep your stock program as one of the maps so you can always get through smog or take your car into the dealer.EniGmA1987 wrote:I just had a quick thought about this and hopefully I dont sound too stupid...
Can you make one of the tune "profiles" set to have lower HP and torque and get less emissions that way? California has some strict emission laws so it would be incredibly useful to have the performance tunes and then a low emission tune so that when you have to take the car to get smogged you can switch to that and pass easier. Or maybe just turning for less HP and torque wouldnt make a difference on the emissions, maybe the car could be limited to 5k rpms or something so if the engine doesnt run as fast then it wont push out as much exhaust? If the guy starts getting suspicious I can just tell him its a factory governor because its a luxury car not a sports car
lower hp tune......LMFAO. Now thats funny.ken in az wrote:
there is no reason why you would need a lower hp tune - that's just nonsense
fiveliterbeater wrote:excellent numbers bud!!!!
glad to hear you like it! get that exhaust ASAP for a more noticeable diffrence!
5L, did you get your car UpRev'd? I believe you were talking about it..
HugeDude33, good numbers! Sounds like it's as much the "tuning" or opening up the ECU as it is the 11 hp your feeling huh? does that question make sense?
#1 Ditch all the factory stuff between the rear mufflers and the headers. That is the main restriction in your exhaust. Surprisingly the rear mufflers on the M45 are a chambered low restriction muffler and are nearly straight through design.hugedude33 wrote:Hey Ken, what exhaust would you recommend. I dont want it to be too much louder than the factory. I like the low growl of the factory exhaust but in order to get max performance out of my car I need to change the exhaust. I spoke to the tech about people experiencing lower power with the injen CAI. He said he would build a hood around the filter that would create like vortex and the air would be sucked in 10 times better. These guys build race cars everyday, thats all they do. They might know what they're talkin about
Backdoc7 wrote:i get my taxes back on the 12th and my car is getting UpRev'd shortly after. trust me, everyone is going to know when i do mine : )fiveliterbeater wrote:
