Blade7764 wrote:I think that a 400 HP Naturally aspirated car sounds better to me than a 300 HP Turbo. What are you thinking? Its going to run fine, why would it run poorly? The engine will be brand new and so will the trans and rear end. It'll smoke any 4 cyl. cause there will be WAAAY more torque. I am here at this forum because I like the body style of the car and the light weight, Isn't that enuf?
Peace.
Its a cool idea, but you will run into some serious drivability problems. I hope you have years of driving experience under your belt, because 400+ ft/lbs of torque would be very hard to drive with in such a light car. Every time you step on the gas with a car like that the back end will step out. Plus it would be absolutly nessecary to stiffen the chassie with a s13 hatch, or else you'll have some perminent deformation.
You can have your own opinions about various engines, but if you call the SR20 a "gayass" motor, then people will diss your idea. The SR20DET is a proven motor, there are several shops making over 500hp on the stock bottom end, and several japanese tuners have brought the motor well over 700hp with aftermarket parts availible to anyone here willing to invest alot.
Im not dissing small block though, Aries on this board has a 350 in his S14 and its a wicked ride.
