ShionS14 wrote:actually the specs that they give you are measured at .050 and they are something like .390 lift and 275 duration, if i remember right...
Yeah, TY said the Ben over at JWT kept calling them 276/276 cams when they are actually 256/256. I dunno, just forwarding second hand info...
But I think that a 276 cam in a 240 wouldn't make power 'til 5500, so I'm inclined to believe that it's a 256 combo...
Quote »also if i get the JWT ecu wont i have to re tune it if i add a pulley and port/polish the head, and bump the compression? [/quote]
No. You could get it re-tuned on a dyno at a shop that could burn you a new chip - i.e. Sunbelt in GA, but again - They can't do anything more for you in N/A trim other than the standard upgrade. They already give you plenty of timing, the rev limiter is up where it should be (any higher and you're KA will come apart in a short while), and the speed limiter is removed...also the tip in retard is gone, and the fuel leaned out.
Remember, a MAF based system will pick up increases in airflow and compensate...not like Honda where you have to bump fuel pressure or burn a new chip or whatever.
I'm not saying there's not power to be found, but JWT cannot give you any more than what they send out to any N/A guy without a custom tune, and that would take dyno time and a shop that could write a new ROM chop for you...
Later - Brian
