Got my block back from shop, what is this?
ripewithdecay
I just got my block from the machine shop and noticed this while i was painting it( dont mind my poor masking job):
What I'm concerned about is the oil filter area and the frayed metal circle with what looks like a spring or heli-coil or something inside it. I can't remember what its supposed to look like and am not sure if I should be concerned or not. Any help would be appreciated.
ripewithdecay
Well I was able to find out what it is. Oil bypass check valve. Should i replace it or just remove the spring? Seems like some people actually weld it shut too. Just not sure how vital of a part it is. Also to anyone who has replaced it, do you have to drill it out or is there an easier way to remove it? http://www.courtesyparts.com/15132m-val ... 23658.html
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Looks like the entire filter assembly is missing.
ripewithdecay
I have the assembly.
ripewithdecay
In case anyone else runs into this problem here is the info to order one on courtesy nissan:
[15132M] VALVE ASSY-REGULATOR - Truck (D21) 1986.5-1995
Item# 15241-D21001
Also if you are wondering how to get the existing one out, here's a "tool" you can make to remove it. I just took a bolt and ground it down somewhat. There are raised tabs on the back of the valve that the "tool" will catch on. I just used vice grips on the "tool" and pulled towards me multiple times and the force of it tapping on the raised tabs made light work of it.
