locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Mon Sep 14, 2009 2:06 pm
I went over to pick apart Sunday, HALF PRICE DAY, to go get a j30 vlsd 5bolt rear end and axle shafts. i went in and found the car i had previously scoped out. but decided to take another look around and there and behold was a 96 with a 6bolt YAYYYYYY i don't have to buy the axle shafts. so i dropped the rear end and payed 60$ for it .
So i was reading the links that someone else posted on the rules for the LSD's and one of the link states that the 95-96 6bolt diff requires no modification and can bolted right up. What about the front covers? (i know for a fact you got to change those.)
The other link says that yo do have to swap the covers and... the 95-96 equipped with ABS has a longer half shaft by about half an inch longer.
"The Infinity J30 uses an ABS sensor that attaches to the input of the diff. If you have an ABS equipped 240, this will be the same sensor ring. This sensor ring requires that you have a drive shaft that is approximately .55" shorter than the non-ABS counterpart. If you do not have ABS, you will have two options. First, you can buy the ABS drive shaft. Second you can buy the non-abs diff input. This information was provided by Bill Redding, also a 240SX chat list subscriber."
My car being a s13 non abs car has a longer drive shaft. and he says you got to find a ABS drive shaft . but i also read somewhere a while ago that our s13's drive shafts have enough play in them to make it fit anyways but cant seem to find the thread anymore.
Can anyone confirm this? and does anyone know about aftermarket solid front bushings for the vlsd, or bushings for the front cover off the s13 Open diff.
