nab911 wrote:Lol well it just hit me after reading that that it may be causing it to stumble but i just figured it would run but just run rich and blow black smoke (which it doesnt). Im broke at the moment but if someone could hook me up with a chip for this at a cheap price i would be very thankful
What do you consider cheap? You will have to get your ECU socketed which will run you about $40-50. I think a better idea would be to find a set of stock injectors and get it all straight first. Then get your hands on some fuel control equipment. And an FYI, if you can't find any stock CA injectors, the ones from a 90-94 AUTOMATIC turbo eclipse/talon will work fine (they are 390cc) and go for about $30-40 a set. 20cc is negligable compared to what you're dealing with now.
EDIT: wOOt! 500 posts
