Got hesitation + ecm throws code 55-sensors all good = HELP!
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
I have a hesitatation (feels like revlimiter) occasionaly under accel. when the engine is warmed up. I did an 5spd swap with a 5spd ecm and wired all the sensors. The ecm was throwing a code 82 after my 5 speed swap so I installed a cps. I checked/replaced all the usuals distributor cap/button, wires, plugs, fuel filter, injectors, vacum lines, o2 sensor, even installed a brand new Walbro 255 fuel pump. Has anyone else had this kind of prob? Any ideas? Please
Ohh and it hesitates either between 750-1500 rpm or 2500-4000 rpm
Modified by Salem240 at 8:05 AM 7/31/2009
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
I have the same problem does the car kinda bog when you start it and hesitates real bad under throttle with some backfiring? I've checked all of my sensors as well.
Salem240
'98 240SX SE
Yes it bogs on itnitial accel. and sounds just like the rev limiter kicks in if you give it more than half throttle, no backfiring (yet). Timing is set at stock spec
Salem240
'98 240SX SE
well, managed to get my throttle position switch replaced just to find out THAT WASN'T IT $#*@ !!!!! anyone have a solution? please help
VMP
Car: 1995 Nissan 240SX SE (sold)
1992 Nissan 240SX SE (sold)
1976 Datsun 280Z (sold)
2001 Honda S2000
code 55 means there are no fault codes zerothread?id=253912
as for the bogging... try putting the auto ecu back in and see what it does..
also.. you have a 95 right? just hook up a scan tool to the dlc on the passenger side and get the P#### code that it will give you and go from there. (only works if the check engine light is on) http://www.wallpaperama.com/fo....html
gl!
Salem240
'98 240SX SE
Yeah, there is no CEL on .... and I forgot to mention that I swapped the auto ecu back in and got the same problem (and throwing 3 codes for the transmission).
Salem240
'98 240SX SE
Maybe a video would help......
Here's the YouTube linkhttp://www.youtube.com/watch?v=DHa2PhKNu-U
VMP
2001 Honda S2000
82 is crankshaft position sensor
i found this in my old s14 rebuild stuffsss http://i15.photobucket.com/alb...s.jpg
VMP
2001 Honda S2000
so basically the crankshaft position sensor (or circuit) has a fault in it somwhere or the sensor itself has gone bad.
however if you just recently had a 5spd swap done.. i'd prolly find someone with a fancy scan tool and set it to remember a 10 minute trip while you go out and test drive it... then some back and review the results. it will basically tell you what the ecu is seeing. gl
also... how trustworthy and reliable are the people who did the 5spd swap... perhaps they didn't install the flywheel or clutch right.
Salem240
'98 240SX SE
I fixed the code 82 already and installed the cps. Still have the same prob and the ECM is showing no faults. One thing I found was the hesitation happens more frequently and sooner after the motor warms when it's hot outside
destroyyourmind
I'm having the same problem mine seems way slower than your video though, I'm going to dyno my car to figure out the specs on the motor and I'll let you know whats going on
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
i bet its your fuel pump. i had the exact flippin problem.
Salem240
'98 240SX SE
NISSAN240SX12 wrote:i bet its your fuel pump. i had the exact flippin problem.
I replaced it with a walbro 255..... recently I replaced the MAF&intake temp sensor and the front o2 sensor (again). It's cutting the fuel out cause the plugs are white and the o2 sensor I pulled was white on the end. I think the only thing I have left to try is the rear o2, fuel pressure regulator, and egr system (might just remove it. NC has no emissions for OBDI cars)
Salem240
'98 240SX SE
For anyone who has the same issue make sure you check your EGR system. After I removed the EGR system and took a closer look at the vacum lines, one of the lines had a really sharp cut in it. It apparently happened when I changed out my motor mounts and pinched against the firewall. The vac lines is one of the first things I checked but I was looking for cracks/dryrot not a "cut". Now that everytihng is removed and blocked off the car runs like a champ. I wish I would have found this before I bought all those parts but oh well.... Lesson learned.... again
