Loveless wrote:i checked your old thread, you have a 92 240sx pop up lights
when you say dim light and bright lights, I think you meant low beam and high beam
if that is the case there might be some issue with the wiring?
maybe there is a relay/fuse involved but I am not near my car so maybe someone else woudl know for sure and chim in
Check your switch, it's the most commun cause of head lights failure.cradle3 wrote:i got both headlights changed and yet im having the same problem. only one dim light will come on but both bright lights come on.what could be causing this?
