I posted the cost. That included resurfacing and cleaning of all the gasket mating surfaces on the head and the intake manifold.srdrps13 wrote:how much are head jobs?
Depends which corner..srdrps13 wrote:how much are head jobs?
capwred wrote:looks good c-rad.
i all so just got mine back and looks just like yours.and the block looks great too.as soon as may rings get her i can start putting it back togather.hers a pic of the block after i put some paint on it.
I paid $162 for the block work. That included tearing it down, cleaning everything, honing the cylinders, decking it, installing new freeze plugs and reassembly.NeedCAforS13 wrote:chris, what did your block cleaning run you again? where was this place... I have a block and head we disassembled tonight that needs to be cleaned up. Did they put the crank and main bearings all together for you as well (new oil pump right?)
i just mask them off.i put three coats of engine primer and three coats of engine paint.tyrannix wrote:did you mask off the unpainted parts, or take them off? (i havnt seen them as budging off at all on my blocks)
New valve stem seals were installed. Bottom end was done by that guy in Palatka who did a less than optimal job. But the second shop (Fred's) checked all the clearances and said that was the only thing he did right. Basically Fred's tore the whole motor down to the bare block and inspected everything and put it back together. So its the same amount of labor as if you were putting new bearings in by them in the first place.NeedCAforS13 wrote:another question chris. did they do the valve stem seals while it was there? and back to your bottom end, did you buy the rod/main bearings and piston rings from them after they measured it all out, or how did you know what sizes to get? They did put the crank and main bearings, and new rings/rod bearings in right? Or did you do that when you got the bare block home?
