beans33 wrote:hey boost boy i took the fuel pump fuse out and sprayed a LITTLE starting fluid in each cylinder and nothing happend . I also noticed when im trying to start the car the tach is not jumping around. Does this have anothing to do with the orange wire that your were talking about. As far as the timing belt goes its on right, I had a couple people help me with it. Ill check on the CAS now. thanks
If you are positively sure you put your timing belt on correctly, codes on your ecu display is 55, you have spark, everything is grounded, and your car ran before, you may want to look into the areas that you worked around such as the engine harness.
As for the crank angle sensor and the key that turns it that's apart of the exhaust camshaft, you car should still run. The crank angle sensor is not only turned by the by the 2 keys between it and the camshaft, but also the seal that's on the crangle sensor's shaft. It's kinda like a failsafe that when all the bolts back out and fall while you're driving, the seal will hold the crank angle sensor in place and also if one of the 2 keys break, the seal also serves as a secondary means of the camshaft driving the shaft of the crank angle sensor.
Beans, you don't need to remove the spark plugs to spray starting fluid! Just spray it down the throat of your throttle body and if doesn't start, then your spark is too weak (if you say spark is present); because no matter what, your engine will do something with starting fluid if you have spark.
Dee
