GOT everything off but know i need to take the front crank seal off!!
kppk1986
I've taken off all the belts and the crank pulley but i cant get that freakin front crank seal out... wont come out with a freakin screw driver... plz help again... thanks!!!
SpeedRacer1
Car: 1990 240SX, G35
Its hard rubber, you must not be trying hard enough. Dont be affraid to break it, you'll never use it again. Do whatever you can think of, just dont scratch the outside metel.
180fan
Car: 89 fastback
Yeah it takes some work to get off with a small screw driver. Just keep at it, it'll give in.
robbbby
At my local tool store I found this screwdriver that looked like the pick the dentist uses to scrape **** off your teeth.It's has a hook on the end so you just sort of hook the seal and pull.
Hijacker
Car: '92 240sx Convertible
'94 F-150
advance auto has a seal puller. it's a T shaped instrument where the upper part is curved so you can hook it behind the seal. very handy
