cory2081 »
https://forums.nicoclub.com/cory2081-u9472.html
Sun May 30, 2004 6:59 pm
Ok, here is a little drawing I made real quick with some deminsions on it. The piece to the top left is the side, the hole is where the intake tube goes thru, it should be made about 1/4" or more larger than the pipe itself so that there is enough clearance for easy installation and for when the pipe may move due to engine torque. The edge of this that is farthest to your left is the front edge, which will end up right behind the headlight. The next piece is the one that is to the right, that is the backside that will keep that radiant heat from the header out. The 5" edge is the bottom, 8" is the top, the left edge will be at 90 degrees to the right edge of the side piece. The piece below that is the bottom. The 8" edge is the front and will come real close to the oval opening where a cold air extension would normally go. I left out the right side (which would end up closest to the coolant resevoir) This piece will be an odd shape and should be measured and made up AFTER the other three pieces are assembled. Now, you can use sheet metal, plexi, whatever floats your boat as the material (as long as it will withstand some heat) I used some little 90 degree brackets that are used for shelving and some sheet metal screws to fasten it all together. All of this can be bought at the hardware store (or even wal mart). 2 brackets for each edge is plenty, 1 for the 5" edges. Once it is all assembled, test it for fitment.....
1. Remove air filter and loosen intake pipe at the throttle body so that it can be moved up or down with ease. 2. Angle the box so that the pointed front edge of the bottom piece is down. It will find its way partially under the coolant resevoir. Insert the intake pipe as the box is lowered down. 3. Position the box for best fitment and mark where the 2 studs that stick up from the chassis touch the bottom of the box. 4. Drill the holes for the studs to go through and reinstall the box.5. Fasted the box down using the nuts from the 2 studs. Make sure the box is all the way down, don't put the 2 spacers that are on those studs under the box as it may make it too high and it will hit the hood.6. After a sure fit is made, you can go ahead and paint it or insulate or whatever you like.
