Chingon »
https://forums.nicoclub.com/chingon-u8507.html
Sat Oct 09, 2004 6:41 pm
so is it functional?
not busting your balls, but for some reason i think there won't be much air going in there. Just think about it for a second. Air travels from a high pressure zone to a low pressure zone. So you have 2 high pressure zones1. the one going in through the front grill and into your bay.2. the one caused by aerodynamics and sweeping through the car's body.
So, if say, high pressure zone 2 has enough time to get sucked into the hole, it will work, but there is just no aerodynamical restriction (mini hood scoop) to redirect the air into the hole. However, I am not condemning your efforts as futile or saying it won't work... Sometimes I like to play engineer.
BTW, a fix for the water would be to use a similar item to that of the installs section where the guy made a hole in the bumper and closed/opened it at will w/some metal open/close thingy.
