got boost gauge hooked up only pushing 5psi
rb20detsilvia
Car: 92 nissan 240sx
i thought stock was 7-8 ????
Carl H
with a catback exhaust boost is 10psi...somethings wrong.
rb20detsilvia
no cat 3inch exhaust
David_NISMO
Car: RB26DETT powered S13
How strong is your car running? Maybe you have a boost leak.
Saw a 626 with an intercooler hole constantly cutting fuel at 5-7psi when boost cut-out is supposed to be like 12. Pre-intercooler was hitting full boost, post intercooler(manifold) was only seeing a max of 7.
Just a thought.
Shocker
Car: 89 240sxHB rb26/30
hmm ill share what mine does for a reference.. ive got 3 inch elbow back, FMIC, stock solinoid and an HKS air intake, im getting 7psi by 2400 rpms and by 5000 rpm its creeping to around 10 psi by 6k to redline boost creeps to around 12-13 ish at times.. ive checked for small leaks in the wastegate lines and solinoid lines.... just from my mods im resolving. could be missing a few turbine fins?
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Should be 10 like Carl said, check for leaks in your boost line. And try a bottle of Sea Foam lol, i got 2 in /hg of vacume ,off cleaning my vacume system lol
rb20detsilvia
ok i rodded on it a little harder and it got up to about 7-8 but it dosent make that till 55k you can hear the turbo spool and it will still blow off at earlyer rpm without showing any boost like 3k it will show mayby 4psi
RB20DETodd
rb20detsilvia wrote:ok i rodded on it a little harder and it got up to about 7-8 but it dosent make that till 55k you can hear the turbo spool and it will still blow off at earlyer rpm without showing any boost like 3k it will show mayby 4psi
try pulling off the bov and inspecting it to see if its not, leaking, then if you feel like ripping **** apart check your waste gate that might be stuck open
Spazz
make yourself a compression tester
rb20detsilvia
Valley
Car: 00 celica gt-s 89 240sx hatch
i think he ment boost leak tester
like this : http://cgi.ebay.com/ebaymotors...wItem
rb20detsilvia
can somone take a pic of there turbo from the top looking at it it looks like the wastegate might be a little open that would explain it
240sxed
Even, without a boost controller, you're suposed to hit around 10 psi creeping?
I think im hitting 7-8 by 5-6k rpms.
I've got full 3 inch, apexi intake, greddy fmic...
SeVa-S13
Car: '05 GTO 6spd
240sxed wrote:Even, without a boost controller, you're suposed to hit around 10 psi creeping?
You have a 25 though. (Less boost)
And on a stock turbo with blown seals and just an open 3" downpipe, I would get 12-13psi. Not that it made any power above 5k or over 3/4 throttle, but still...
rb20detsilvia
ok figured it out my wastegate was open a little bit took off the bar and tweeked it a little so it would hold it closed with a little pressur now it gets 10 psi thanks for all the advice
David_NISMO
It's nice to see the forums helping someone fix problems like these. This could have taken you forever to find.
