SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Fri Nov 28, 2003 11:17 am
Speedometer Error Formula
original tire revs per mile / new tire revs per mile X indicated speed = actual speed
To find our answer, we need to first find out tire Overall Diameter(OD), then find "tire revolutions per mile"
original tire is 205/60-15(OD 24.69")new tire is 205/50-15(OD 23.07")
Finding revs per mile is easy: 20,800 / overall tire diameter = tire revolutions per mile
...so..
revs per mile for 205/60-15 is 842.4205/50-15 is 901.6
.. now assume you're cruising at an indicated speed of 60mph, and put those revolutions per mile into the original formula...
842.4 / 901.6 X 60(this is your indicated speed) = 56.06 actual mph.
842.4 / 901.6 X 70 = 65.4actual mph
All the work is done for you now, just plug in whatever tire sizes you choose, and find your actual vs. indicated speed.
A given tire's overall diameter can be found on most all manufacturer websites...
To my knowledge, the above formula is correct, but it's getting late....
Remember there is a percentage of error in speedometers, and in measuring tire OD, so this is not absolute spot on exact to a decimal perfect, but it's close, and it's an excellent tool to clue you in to what's going on with the car, when you alter from OE sizes.
PHIL:)
