Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Tue Oct 05, 2004 8:03 am
i was finally able to borrow an mdm techdom to put on my car. im running an msd btm on a stock auto ecu (i converted to 5spd). my problem was at any setting past .5 degrees of retard for every pound of boost my car would fall on its face having no power. i thought my base timing might have been too retarded, which it was but by only 3 degrees. well i plugged the mdm in today and took it out for a little while.
under WOT i was getting readings of 14-17degrees total timing on the stock ecu!!! for those that arent too familiar with timing let me explain a couple things. the stock ka ecu supposivly runs about 26-28 degrees total timing under WOT and peak load. if you do anything to change timing via btm, emanage, or retarding base timing you will still see the original ecu map on the mdm. to read how much you retard the timin you would need to be on a dyno with a timing light.
i even set the btm to 2 degreees of retard per psi of boost and it had no power but the timing on the mdm read the same as when i was at .5 degrees of retard per psi. im runing 13psi right now so at .5/psi that would be 6.5degrees of retard and at 2/psi that would be 26 degrees of retard. yet either way the mdm still reads 14-17degrees at wot in 3rd at 4th gear under full load.
i already talked to klattr1 and he is stumpped. does anyone have any idea how my stock ecu could be doing this? im going to try to get a hold of a local 240 friend to get the mdm on his car and see his readings.
