got abs? in rb25-240 swap
hybrid2012
I posted this in the technical forum, but I thought I might be able to get some good answers in this forum too.
I'm trying to learn as much as I can on the RB25-240 swap. So thanks in advance for any info.
I know it should be possible to keep the abs in the swap, but what all's involved? Do both the rb and 240 have to be equipped or just the 240? Does anything have to be done regarding the driveshaft? I found this which seems to take care of the wiring.
http://www.wiringspecialties.com/r33rbins1424.html
Is there anything else needed to get this done? Thanks again
gawdzilla
Car: none
nothing special needs to be done. abs is a separate harness, and your ecu doesn't know if your car has abs or not. just leave the abs wirese there and everything connected and it'll be fine.
cvc9216
gawdzilla wrote:nothing special needs to be done. abs is a separate harness, and your ecu doesn't know if your car has abs or not. just leave the abs wirese there and everything connected and it'll be fine.
yes. I have ABS working fine in my S14-RB25 swap
Carl H
on s13's abs is part of the efi harness, s14 is diffrent i guess.as long as the sensors are in place abs should function fine.besides who needs abs, learn to pump the pedal quicker
cvc9216
the abs wiring is part of the s14 engine harness. you have to remove it and add it to the rb harness or run it separately
havik420
Car: 91' 240sx RB25
how can you tell if it once had abs, im trying to by a driveshaft for mine fron shaftmasters.com
virus77
Car: 95 S14, 71 240z, 97 e320
the nose of your differential input shaft will have a sensor right by the flange area. Also you would have the ABS module and associated plumbing hooked up to the brake master cylinder unless all that has been removed. The standard diff has no sensor so the nose is a bit shorter, the longer diff with the sensor causes the difference in dshaft lengths.
