Pitts »
https://forums.nicoclub.com/pitts-u231537.html
Fri Mar 28, 2014 5:30 pm
Okay, bigger problem it seems like. The seller of the window motor said they load tested the motor (over 5500 positive reviews, so I took their word). However, even when using my power probe to run the motor without the switch, no go. for both motors. Is there something that I may be missing? The regulator moved fine and wasn't snagged on anything when I disassembled the assembly to remove the old motor. Or is it just that the motor was indeed crap? I know engines, not all the accessory crap (other than wiring it up).
