Rather confused with some of your term like "towed in" and "my rear comes from under my car." Are you saying you have excessive negative camber or excessive negative toe? Is one of the arms cracked? Or just a bushing failed? Tire wear pattern will tell you a lot, assuming correct inflation pressures.
Start with the FSM and inspect it carefully and post back, please.
http://www.nicoclub.com/FSM/Q45/
