got a quick quesion about alternator.
Maximum_RPM 240
Car: 240 Sr
I have a 96 with s13 sr20det.
the 100 amp fuse in my fuse box kept poping and id have no lights or assc at all expect headlights and car would start.. after 2 weeks of searching, harness and all, i took the alternator power wire off and put a new fuse a everything worked.
When you have the power wire on and you connect the neg battery wire it would spark and pop the fuse.
i no there some kind of plastic washer for it, mine broke a lil but its a full circle.
on the ring of the power wire there like 2 "stems" on opsite sides on it, not sure if thats how its goes? i cant figure it out. ground is good, i have a test light. any1 please help?
180fan
Car: 89 fastback
you need that plastic ring, it keeps the power from grounding out which is why your fuse is blowing
180wanabe
Car: 90 240 hatch with 91 dual cam
if its still a full circle just make sure its not touching the body of the alternator if it isin't and its still causing this problem you probably have a ground short in the alternator and its connecting the positive and negative battery terminals basically and your real only option is replacing the alternator.
