got a question
nissansilvia89
if i am tryin to reach around 350-400 horse which engine would be cheaper to do that with??? the sr20det or the ca18det??? please help me as i cant decide which one to buy:) :)
DonDonati88
sr20det...
nissansilvia89
by how much though??? and what kinda moda am i look in at i know like exhaust, turbo upgrade, internals, fuel, and the electroinics but ne other suggetsions???
Daunttless
You're looking at about 9,000-10,000 dollars for engine/parts/installation. Enjoy your day.
sillbeer
Car: cars and outdoor stuff
The cost will be about the same like dauntless said. There wouldn't be any real cost differences between the 2 setups. If your going to buy a full turbine setup it usually costs about the same price for two closely spec'd turbos. You can use stock bottom end to achieve the the 350-400hp level on both engines. You'll just have to spend some time on head work.
-Destin
nissansilvia89
i there ne resources on how to port and polish ur head urself?? what kinda shop would u have to goto?? also how can u say there the same when the ca18det is almost sr20det??????:ylsuper
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
DIY port and polishing -- http://www.sa-motorsports.com/diyport.htm
I've used this port and polish method on two of my friends' heads and it worked great. One was a GS-R (B18C1) head, and the other one was a lowly D16 head (really made a difference).
I used the method above with an added extra method of using a flexible shaft and flap wheel to smoothen out the inner ports that can't be reached by a conventional shaft.
sillbeer
I never said this ""also how can u say there the same when the ca18det is almost sr20det??????"
There similar motors. The ca puts out 185hp and the sr puts out 205hp. There both 4 cyclinder turbo setups and with similar mods you'll see similar results. You'll just have to make the ca push a little more air to achieve the same (or as close as possible) results. So maybe slightly different cams and turbo setup. It doesn't matter wether you buy 256 degree cams or 264 degree cams there gonna cost the same. Same goes for turbo's. If you buy an hks gt-rs or the hks 2835 there both in the same price range and with the two setups you'll see similar outcomes. My point is your gonna spend the same amount on each setup to achieve the same goal. In my opinion I would build up the ca since it has a cast iron block but there aern't as many parts available for it as the sr. So I would have to go with the sr. Just my 2 cents.
-Destin
ItzGenX
After you get into the big horsepower and larger mods, the displacement between the two will seperate them in the crowd. Also he is correct on getting parts for each. SR20 is just flat out more popular.
Daunttless
<shameless plug> I'll be stocking a full line of CA parts. : ) <end shameless plug>
ItzGenX
LoL!! :cool: So dauntt, when is everything going to get up to speed? What are we waiting on? (besides the motors)
DonDonati88
sillbeer wrote:I never said this ""also how can u say there the same when the ca18det is almost sr20det??????"
-Destin
Ca puts out 175hp not 185hp. I had a 85 200sx turbo ca18et
Justice
Car: turbo's
you dont need 10 grand to get 400 horse out of a sr.... just turn up boost... it will all work itself out.
