Got a problem with the versa...advice?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Johniboi
Car: Versa
So yesterday I realized that there's a problem on my rear window.The problem is that everytime i try to "send" water down that little hole above the window, instead of the water going outside on the window, it goes inside my trunk and starts dripping from the top on the trunk door. I'm planning on taking the car to the dealership to get it fixed under warranty but is there a way to fix this myself? Also, this problem should be fixed under warranty am i correct?
Thanks guys
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Yes, it's probably something as simple as a hose not connected correctly inside the body, but if you broke a piece or messed it up then they might not fix it without charging your for your "damage". It could also be a broken hose, though, and then you'd have done all that work. Either way, iIt would definitely be a warranty fix, and I'd let the dealer do it. (Yeah, I'm a wimp!)
1_Sleek_Versa
Car: 08 Nissan versa SL
Happened to me too!
The problem was the hose was pinched at one place. I guess it was just a mistake at the plant. Fixed under warranty alright.
On a side note, it's not water. LOL
blindsnyper
Car: 2007 versa
its water if thats what he tops it off with
Red Devil
Car: 1990 240SX w/t SR20
Blow it up. Every problem can be solved with the careful application of high explosives.
KimberKenobi
Car: the Camel
Red Devil wrote:Blow it up. Every problem can be solved with the careful application of high explosives.
"This is how we fix things on Russian Space Station!"
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
We tried this with Iraq, and the results were less than desirable.
xtwoonamatchx
Car: 2007 Nissan Versa S
ok, does EVERY versa have a working rear nozzle? since july 07, i have yet to have my rear nozzle spray... i hear the pump when i push the wiper stalk forward, and the wiper blade moves, but it nothing comes out... i saw the hose when running wires for my amp, but they were dead empty.
Andrews Chalmers
Car: Versa '07 SL CVT
xtwoonamatchx wrote:ok, does EVERY versa have a working rear nozzle? since july 07, i have yet to have my rear nozzle spray... i hear the pump when i push the wiper stalk forward, and the wiper blade moves, but it nothing comes out... i saw the hose when running wires for my amp, but they were dead empty.
Use a needle to clean the spray nozzle. If that doesn't work - take it to the dealer.
Return to “Versa Technical Discussions”
