Sleeper s13 wrote:I was told at hibdon tires that the ft/lb torque requirement for my strut should be at 100. so i got a torque wrent and a breaker bar to remove the strut bolts so i could mount my tower brace. got it of and then when i went to tighten them the bolts broke before me wrench reach a 100lb click. please someone tell me the torque specs for a 92 240sx strut bolt asap.:help
You're talking about the strut to body bolt, right? That should be between 29-40 ft. lbs, not 100 ft. lbs Are you sure they weren't talking about the strut to knuckle bolts? That torque spec is 114-133 ft. lbs.
Obviously these are two entirely different issues. I am also going to move your thread into the mechanic forum. Good luck!
Andy
