NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Oct 24, 2003 8:22 am
no major incedents on this vehicle yet. make sure 60k service was done. If its a 3.3l it gets a t-belt at 105k. known incedents on the 3.3l is a coolant leak from where the upper rad hose pipe bolts to the intake manifold. dont get water on the 4 o2 sensor connectrs mounted on the right hand valve cover. It could cause it to throw false o2 codes. certain factory wheels for the 2000 xterra had a recall but it was limited. there was a recall on the drivers side air bag connector make sure that was done. there was also a recall on the fuel cut valve in the fuel tank. there are a couple other small recalls on the xterra model but cant remember them. best way to check for applicable recalls is go to your local nissan dealer and have them run your vin on their DCS. other then that they are pretty rugged reliable vehicles.
