got a new 240sx!!....with problems...
shanep1991
Car: 1990 DOHC swap s13
i just bought a 1990 240sx with a DOHC swap and it doesnt run right, it is hard to rev, and has no power. idk who did the swap but it wasnt done very good, i cant figure out whats wrong with it, it seems like a timing issue, theres also a couple things that arent connected, theres a sensor and an o2 sensor thats unplugged
i never uploaded pics before so sorry if i dont do it right!
i have no idea what this sensor is, its just laying there doing probably nothing, any ideas?
this is the o2 sensor, its on the #1 exhaust pipe, does it need to be connected?
this is when i was pickin it up
it has adjustable coil overs all the way around, i got new tires for it today, just need to quit bein lazy and put em on!
but does anyone have any idea of what my problem with the hard rev and no power?
shanep1991
forgot to mention, the engine was rebuilt i guess, so the distributer was out and the chains were off which leads me to believe something is a tooth off. is that a hard fix?
gnubberlang
Car: 1995 240SX SR20DET
2004 Frontier 4x4 Crew Cab 5-Speed
Sounds like you're on the right track. Probably a good idea to double check the ignition then engine timing. Not able to recall what that connector normally runs to.
Timing adjustment isn't bad. You could probably look at one of the head gasket replacement guides and start where it describes re-timing the engine. Just be careful ... this is an interference engine :)
shanep1991
yeah im hoping thats what it is, what is the more common part for people to not put in right? the distributer?
gnubberlang
I don't know if it's more commonly screwed up. Definitely easier to fix if it's wrong though.
