jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Fri Jun 20, 2008 3:24 pm
Went out to the track on Tuesday for test and tune. Since last time the only things I changed were that I took the extra fuel out up top, dropped tire pressure down to 25psi, and tuned the nitrous setup. It was running 11.5 afrs up top so that's an improvement over the low 10s. However, I was still spinning badly way out past the 60' all through 1st and 2nd. Although the nitrous is now keeping me from bogging and I have full boost shifting into 3rd. I did notice at the top of third I'm still bleeding off pressure. It was hitting 20psi and quickly dropping down to 15psi. I checked again for boost leaks and didn't find any. I still suspect the oem recirc valve. Drag radial are going to make a huge difference.
My old slip: My new slip:R/T 1.232 .93860' 2.238 2.118330' 6.035 5.7781/8 9.071 8.72MPH 82.92 84.901000 11.601 11.2011/4 13.761 13.320MPH 104.81 104.44
ps most embarrassing run of the night=18.2@106
