Got a gasket set, which ones are these?
airman86
While disassembling the engine, I don't recall taking off anything that had these:
i numbered them (obviously) to make it easier to point each out.
thanks for the help leddies and gennemeh.
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
airman86 wrote:While disassembling the engine, I don't recall taking off anything that had these:
#1 exhaust flange between manifold and downpipe.#2 egr #5 coolant bypass somewhere can't remember.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
#3 is the egr that goes to the flange that connects to the metal pipe.#4 goes to a little black box that connects to the front cover that has the hose that goes to the underside of the intake manifold
Firewind
Car: 240SX
95silvia14 wrote:#3 is the egr that goes to the flange that connects to the metal pipe.#4 goes to a little black box that connects to the front cover that has the hose that goes to the underside of the intake manifold
Are you sure about #4, because I am pretty sure you're wrong.
#3 I am unsure of as well, since I have removed my ERG.
#4 is for the IACV It's on the back of your intake manifold. Here's a picture even.
http://i36.photobucket.com/alb...3.jpg
airman86
as soon as i can get the part off of the exhaust manifold, i'll be sealing it off with a nickel and some jb weld - will jb weld hold up to the temps of the exhaust mani? i saw someone physically weld a coin in there.
thanks for the help so far.
AZ89two4Tsx
I'm pretty sure #2 is the head gasket. Yeah, that's what it is.
ss82480
Car: 1992 240sx Coupe
#4 is def IACV, I have replaced a few.
airman86
alright thanks guys. anyone know about using jb weld and a coin to block off that plug on the exhaust manifold?
95silvia14
i was just guessing i couldnt remember if that black box had 2 or 4 bolts
